This thread is originally about controlling a video gauge via speed. Your question about intro I believe is answered in another thread.
If you want video on app start up. It wonāt play on app turn off.
Now for video on key turn instead. Use the same triggers and actions as mentioned but 2 issues. One your video will play but itāll stay on the screen so if itās full screen it wonāt show whatās behind it. Youāll have to add a fade in and out action.
Secondly youād need to decide input for it reading. Using voltage would be my suggestion. Once battery voltage is above 0 play video gauge and fade out at same time. When battery voltage equals zero again fade in and play
hi can u help me regarding this
so basically i want to create a video that goes with the rpm of the car, with the rpm increases the video goes forward and goes back with the lowering.
Currently this can only be implemented as triggering the animation to be visible when RPM goes above certain limit and triggering another animation when it goes below.
So basically if i do it with single image frames is possible?in case yes what are the right settings? Ty
@Frankydap Iām trying to do something similar, did you end up figuring it out?
Hey @realdashdev, Iām quite new to this. I tried following what you said and hereās what I did:
- I had a gif, I converted the gif to a zip file of pngs (each representing a frame) - so basically sprite animation
- I went and created 23 image gauges and imported each one of the images into a gauges - named them Frame 1 through Frame 23
- I went and created a trigger for each, so trigger 4500-4600 is basically when the engine RPM is more than 4500 and lesser than 4600 then I trigger an action āShow Gaugeā and show frame 1
I did it this way so that when the RPM is dropping, the video can play backwards.
It does the job but I need to set another set of triggers so it hides the gauges when thereās not in that RPM range. It does the job but oh boy is a whole lot of clicks to set this up. Is there a faster/easier way to do this that Iām unaware of?
Thanks!
Hi. there is no such way at this stage.
Thanks a bunch. I used Keyboard Maestro and quickly set up automation to do it for all frames. I finally got it done, Iād post it here but itās very NSFW lol.
Cheers!
Iām a little confused about what youāre talking about. Could you please demonstrate your work?
