Critical error WriteInterval and send can frame from RD to CAN
v 267 win
1 Bugs frame ‘writeInterval’ attribute (optional) I don’t see any difference; I set the parameter to 1000, and I still see series of packets every 30 milliseconds.
2 I needed more than two frames to control the cruise control — two of them work more or less correctly. In the third one, I don’t see any changes when changing the variables in RD.
3 Timing - i rotare change valuy every 100 ms - bu i see in CAN monitor series 5 - 10 pack 30 ms
if return to RD 264 - timing is as need 100 ms - i rotare every 100 ms in get in monitor 100 ms =
  1. If you use specific variables, you won’t see any result if you use two different variables or more.
File for test i ready to send
Rotate value in Global triggers
Golobal Triggers on / of changes - changes sets only if restart APP (continue work if preess enable ( empty circle))
frame ‘writeInterval’ - They only work if the values in frame do not change, but any change in the value causes a series of packets to be skipped.
RD android work same (30% more fast 20 ms rotate CAN packs )
RD264 test same config/RD/XML - timing is good
also i test for this BUG 265-2 / 266-2 / 268 - all ok
269 and 270 - problem/
result - use 268 is more good
