The OBDLink MX+ is a Bluetooth adapter, so it won’t become a USB-serial device just by changing a setting. For 33.3 kbps SW-CAN you’d need a USB OBD interface that explicitly supports GM SW-CAN, then add/select that Serial/USB connection in RealDash and set the correct COM port and baud rate. Confirm the adapter’s SW-CAN support before buying, since many USB cables only handle standard HS-CAN.
