I’d like to use physical keys for input control.
Is it possible to use a USB keyboard to send commands to the LINK ECU via RealDash CAN?
Yes, you can create a trigger with Source Input as ‘Keyboard Status’ and then select a key that will trigger.
Could you tell me how I can set it up?
- Create a trigger with ‘Keyboard Status’ as input data
- Attach actions that change values on your Link ECU to that trigger.
