Hi. Can you please check the bug? The problem appears when some devices come out of sleep. The map stops following and the position of the indicator does not receive coordinates. This can be fixed if you go into the settings and turn off and then turn on the internal GPS. But the problem will happen again if you put the device into sleep mode.
We have about 10 Android devices on testing rotation and none of them behave like that. So in order to investigate and fix this issue, we would need to have exact same Android device and setup. We just do not have resources to get them all, sorry.
I understand it. Sure. This is a feature of the system. It would be great to at least be able to restart the internal GPS using triggers and actions. that would be enough.
Is it possible to create an action in triggers that will restart the internal GPS?
I do not like it. To my opinion it has no other purpose than fix an issue that is actually somewhere else. Contact your device manufacturer and ask them to fix the GPS activation after sleep.
