When I add a text gauge and link it to the “System Notification” input (ID248), I noticed that the some of the notifications RealDash sends are still present and replacing previous notifications, even when disabled in Settings > Notifications. This also happens when I filter apps using the ‘System Notification Filter’ field.
Specifically, the speed limit warning notification (“You are speeding. Speed limit is <value of ID67>”) still shows as text but doesn’t send an actual notification when “Speed limits as notifications” is disabled. Is this the intended behavior; and if so, how does one fully disable this notification?
As an interim solution, I set the value of ‘Speed limit warning threshold’ to a value far higher than the maximum speed of my vehicle, e.g. 300 or 500.
There are two separate types of speed-related messages in RealDash:
“Speed limits as notifications” controls messages announcing a change in the road’s speed limit. It does not disable the “You are speeding” warning.
“Speed limit warning threshold” controls how far above the speed limit you must drive before the speeding warning is generated.
The System Notification Filter applies only to notifications received from other Android apps. It does not filter messages generated internally by RealDash.
Input ID248 contains both incoming Android notifications and RealDash’s internal messages. This is why a speeding warning can replace the text shown by your gauge despite those notification settings.
Currently, there is no separate switch to disable speeding warnings completely. Setting a sufficiently high warning threshold, as you have done, is a valid workaround.
