Ok so finally back to the drawing board on this build. Truck has been getting built and life has just got in the way.
I have a rp4 I think lol. I’ll have to check but will buy a different one if need.
Need someone to walk me through setting up and isn’t align android on a rp so I can run an external display and install and run RealDash.
I do have an android radio screen I installed RealDash on to play a round with.
Would anyone be willing to chat here, Facebook, WhatsApp email or other to help me get this project going and rolling along. Heck even text would be awesome.
Josh.
sudo apt install -y /home/pierrejovan/Downloads/realdash-mrd_2.7.0-1_arm64.deb
thats my code for my pi5 it may work but you will have 1. have to go to myreal dash and download the latest realdash-mrd 2.7…and what arm your pi is also your file name wil be differnt from mines
Josh, the install command only works once you know your board’s architecture—the filename in that example points to an arm64 package, so check with uname -m before downloading from the RealDash site. On the RP4, Android is possible but not the smoothest path for an external display plus RealDash; a plain Android build or running it through a supported Linux image may be less frustrating. I’d suggest starting with the official RealDash docs on the Pi, confirming your Android screen works as a display, and testing one piece at a time before wiring it into the truck.
The architecture check is the part people skip, and then the install line fails confusingly because the filename doesn’t match the board. On the display question, it helps to know which Android radio unit you have, since some can take an external signal and some can’t. If it’s just mirroring, that’s a different setup than a proper secondary display. I’d confirm that first, then decide whether Android on the Pi is even worth the extra troubleshooting, as the previous post suggests. Test each piece on the bench before it goes in the truck.
