I have an R33 Nissan Skyline with an RB25DET engine that uses the Nissan Data Scan 1 system run through a 14 pin Consult adapter. I’m currently running an android head unit and run the Nissan Data Scan app for full time current engine diagnostics. I want to upgrade to using RealDash so that I can customize the interface and add some more functionality. I have the app downloaded and went through an initial setup. NDSI1 is listed as an interface so I set that and the baud rate should be 9600. I’ve set it at that rate and run the engine waiting for it to connect. It brings up the connection box in the bottom right corner once, does not seem to connect but then does not re-attempt connection the way that it will if the baud rate is incorrect.
Anyone try this and have any luck with NDSI1 and a 14 pin connector?
