When using a text gauge and setting a rotation angle the bounding box and justification should rotate with the text.
I am creating a vertical orientation dash to used with my phone and I have some text gauges, I can’t get them to line up, and stay lined up with the current way the justification does not rotate with the text.
The second thing is I would like to be able to set the rotation angle of the text on a gauge (needle, arc, ect.). Currently it is either orientated straight with landscape mode or rotated toward the center of the gauge.
In my above gauge I’m working on I have a gauge that when I set it to rotate the numbers are upside down.
@dgieg I believe it doesn’t adjust as the x, y, width and height would have to also adjust.
I’m having trouble understanding how gauges don’t line up due to the text justification when you can enter manually their position.
Gauges with text in them and an image the text can’t be rotated. Example would be arc gauge. You can start at 180° and go 180° so from bottom to top clockwise but the rest won’t rotate.
BUT with that said, if it’s a custom dash, why not just make a flat image in Photoshop. The text come out a lot crisper in a custom image. I personally think this would be the easier route. Yeah you got to do some math but I don’t ever find that to be super problematic.
