A problem for the connections Can and XML file
hello, I have a connection problem with my obdlink cx adapter… I can connect in obd2 but not in can…
in addition I would have liked to get help to make my indicators work… because nothing is displayed on the premium dashboard that I bought… I don’t understand anything about the XML file can you help me create one please ??
atd
OK
atz
atz
ELM327 v1.4b
atl0
atl0
OK
ate0
ate0
OK
ats0
OK
atsp1
OK
atdpn
1
0100
NO DATA
0900
NO DATA
atpc
OK
atsp2
OK
atdpn
2
0100
NO DATA
0900
NO DATA
atpc
OK
atsp3
OK
atdpn
3
0100
BUS INIT: …ERROR
0900
BUS INIT: …ERROR
atpc
OK
atsp4
OK
atdpn
4
0100
BUS INIT: …ERROR
0900
BUS INIT: …ERROR
atpc
OK
atsp5
OK
atdpn
5
0100
BUS INIT: ERROR
0900
BUS INIT: ERROR
atpc
OK
atsp6
OK
atdpn
6
0100
4100983B0011
0120
412080000000
0140
NO DATA
0160
NO DATA
0180
NO DATA
01a0
NO DATA
01c0
NO DATA
0900
490054000000
atpc
OK
DETECTION COMPLETE
PROTOCOLE SOUTENU: 6, ISO 15765-4 CAN (11 bit ID, 5
00 kbaud)
0100: 0x983B0011
PIDS SUPPORTÉ (HEX)
01: Monitor status since DTCs cleared. (Includes ma
lfunction indicator lamp (MIL) status and number of
DTCs.)
04: Calculated engine load
05: Engine coolant temperature
0B: Intake manifold absolute pressure
0C: Engine RPM
0D: Vehicle speed
0F: Intake air temperature
10: MAF air flow rate
1C: OBD standards this vehicle conforms to
20: PIDs supported [21 - 40]
0120: 0x80000000
PIDS SUPPORTÉ (HEX)
21: Distance traveled with malfunction indicator la
mp (MIL) on
Thanks you :pray::crossed_fingers:
You are talking about CAN connection, but your post contain only OBD2 connection info.
Asking to help to create CAN connection without knowing vehicle year, make, model, hardware modifications, etc will not give you a lot of answers. Mixing your question with output from OBD2 will just confuse even more.
I’d recommend that you find a friend or colleague who can spend some time with you and your vehicle to get started.
