Accessing files with RealDash v2.6.7
About the Android version of RealDash :
  • the popup window is empty when accessing files
#1 CUSTOM CHANNEL DESCRIPTION FILE in the garage section
#2 Edit>File>load…
#3 Edit>File>combine…
#4 Edit>File>import animations…
#5 Edit>File>save as…
Local dashboards still present in the Gallery window.
  • workaround for animation and obd2 xml files : modify files in documents/RealDash
Can anyone confirm this bug ?
My Android version is a little bit old : v11
i can not load any files (config/xml/rd) from any usb disk (file manager) / google_yandex disk - forced to use 266_2
Please make corrections in the new version. , The file system is fully not functional. Thanks
2.6.7-2 for Android did not fix this issue? On a quick test with 2 different Android devices, the file import functionality works as expected.
This version did not solve the problem.
The problem still isn’t resolved; the “napkon” folder appears at the root, and the “realdashe” folder appears inside it, but when you add files like dash, garage, or XML, the app still doesn’t recognize them. If you download the previous version—like I did with 2.6.1—all the files you put in the folder show up. I noticed that in that version, the “realdashe” folder contained subfolders like Descfile, camera, datalogs, dyno, settings, trackdays, and tripdiary, whereas in the current version (2.6.7-2), those folders no longer appear. I wonder if that’s the reason the files aren’t being recognized.
My problem persisted, and to solve it I had to revert to two versions of Realdash.
Hi. Has anyone solved this problem on Windows? Unfortunately, I can’t download the previous version on Windows. Maybe someone has it.exe file for Windows?
