Hello, I need some help with certain triggers and settings. How can I activate the camera in conjunction with the turn signals? Could you please explain the method clearly?
On high level:
- Make a Video Gauge with camera
- Create a trigger that shows video gauge when turn signal input is on and hides when its off.
- Alternatively you can use a timer that is reset when turn signal is on and it hides the video gauge when timer runs to, say 5 seconds.
For example for any on/off (zero or one) value:
- It’s on when its greater than 0.5
- It’s off when its less than 0.5
You should read the turn signal input, not a blinker output, otherwise your camera view may turn on/off with the blinker.
Thank you, Jani, for your patience with me. Where can I find the {turn signal input } and thanks agen
To clarify, this is data that your turn signal is turned on, not a flashing turn signal itself. RealDash does not have an input for turn signal being turned on, you have to use a custom value for that.
