Activate the dual warning signal from RealDash
What is the procedure for sending a frame to activate the dual warning signal?
0x05f;00;00.01;00;00;00;00;00=off
0x05f;00;00.02;00;00;00;00;00=on
i need to run it from button RealDash .
Use the ‘Send CAN Frame’ action with a button.
Could you please provide an explanation with an example? Thank you, Janem.
I just need to understand how
Blockquote
Blockquote
My car’s readings frame above
What frame should I send?
  • First try to send the frame in CAN Monitor to verify that your vehicle accepts those commands.
  • Next, create a button and a new Action for it
  • Use Action Type: Send CAN Frame and specify the frame ID and bytes in Action Edit screen.
Another (maybe better) option would be to specify the value name for frame 0x05F 3rd byte in CAN XML file. Then is relatively easy to toggle that value between 1 and 2 with a button.
What frame should be sent, and how does it comply with the static data of the vehicle? plezzz I want to understand the topic completely. :thinking:
Thank you, Janem, for your patience. :rose:
I do not know your vehicle CAN bus to say ‘what’ you should send to it. Only thing I can help you with is ‘how’.
Thank you, Janem.
I have an OBDLink CX. I USE CAN OBDLINK
Hazard Switch :
0X1f5=00:00:00:00:00:14 :00:00…off
0X1f5=00:00:00:00:00:17:00:00…on
For me, it seems like a fifth bit is swithing with hazard switch, so add to your XML:
<frame id="0x1f5">
   <value targetId="166" offset="5" length="1" startbit="4" bitcount="1" units="bit"></value>
</frame>
After adding this to your XML file, you should see ‘Hazard Switch’ input change on RealDash when you press your vehicle hazard switch button.
Now you can make a button to RealDash and add an action that toggles ‘Hazard Switch’ input. When you press a button, an updated CAN frame is sent automatically to your vehicle.
Note, that your value in frame 0x1F5 is probably a status indication, if your physical button is down or not. It means that writing this CAN frame may not actually activate your hazard lights. Typically manufacturers your different frames for status and control.
