I can see how to add a custom map to an ADS input. Where I can create an input/output mapping.
I’m looing into building a tranmission shift indicator, essentially a potentiometer connected to the transmission shift lever. When the position is changed the pot will output a different voltage.
I’d like to be able to use a custom map that takes an input value and maps it to letter, P, R, N, D, 2, 1.
When I try to put a P into the output map, it doesn’t like that ![]()
Is there a way to do this?
thanks
david
