Please add support for the new Dual CAN adapter, here’s the VID and PID.
This is a USB CDC device, is it possible to show both CDC interfaces? and maybe give them different names? I do this on Linux with this script below, can we make Realdash detect both interfaces ?
Will be in next release. Dual needs to have either different names or different serial number, otherwise there is no way to know into which one to connect.
Thanks for that. They can’t have different serial number or names (to my knowledge). On Linux I can know which one to connect using “bInterfaceNumber”, it’s either “00” or “02” not sure if you get the same attributes on Android?
I’ll send you a unit next week so you can try it out.
I finally tried the dual channel CAN adapter from MeatPi. Adapter seems very fast and reliable in receiving CAN frames, but unfortunately it does not send any frames to CAN bus. Could you check on your end what could be the reason for this?
Just tested the latest firmware and it is not yet working. When sending a CAN frame from RealDash, I can see that receiving device gets the frame with correct id, but data length is 0 and there is no data bytes received.
I will make a new feature to RealDash CAN Monitor to allow sending CAN frames directly from there to make testing easier.
