- targetId 169 Cruise Control Active in RD243 It can only take values of 0 or 1 please expand this variable to one byte. in real machines, this example can take more values, for example 0 is off, 1 is on yellow, 2 is on green, 3 is flashing. 4 flashing fast and possibly other values3.
- New ID Speed Limit - make it similar to Cruise control is active (one byte)
- New ID Speed Limit Set Speed Value - make it similar as ID 171 Cruise Control Set Value
- New ID Oil ligth - one bye - as ID 65 - for example, on a Mercedes, there is a universal warning lamp that is triggered by a low oil level or low oil pressure
- ID 65 - from 1 bit to one byte as i wite before - It can take different values, not just 0 or 1
- New ID Bat ligth - battery error lamp
- New ID Steering error lamp
- New ID Transmission error lamp
- NEW ID ESP - The lamp of the ESP system can also understand different meanings
- New ID TMPS light - the indicator lamp of the tire pressure monitoring system
- ABS Warning ID 273 - I also ask you to allow values other than 0 and 1 - for example: off = 0 , on = 1, flashing 2, flashing fast 3, lit red = 4.
- New ID Warning about fastening the passenger’s seat belt
this will make it possible to unify the created content as much as possible
Regars
Falcon
