Adjusting Values on Purchased Dashboards
Can I change the limits and values on the dashboards I have purchased. I bought Bavarian Powerhouse and it is in KPH. I would like it to be in MPH and I would like the Tach to go to 6500.
I have read the tutorials and have not found my answer.
Thanks.
All our dashboards change units (MPH/KPH etc.) automatically by selecting the units in ‘Settings->Units & Values’.
Unfortunately the Bavarian Powerhouse has fixed RPM range of 8k. On most of our dashboards you can adjust the RPM range by setting the engine max RPM:
  • Open top menu and tap ‘Garage’
  • Tap vehicle hood and adjust the ‘MAX RPM’ setting.
Thanks.
Can you please list which one has adjustable RPM red line and max speed setting?
Thanks.
Hi @realdashdev, Can you add a “Speed Units” integer input (0 = km/h, 1 = mph, 2 = knots, 3 = mps) to use as a conditional trigger? The automatic text conversion on the current gauges doesn’t look good, so I need this input to manually show/hide the dedicated KM/H and MPH image gauges.
Or simple:
Speed Units KM/H: 0/1
Speed Units MPH: 0/1
Speed Units KNOTS: 0/1
Speed Units MPS: 0/1
