Is there an xml file available, or can one be made to get AEM 6 Channel can sensor module working with real dash?
https://www.aemelectronics.com/products/cd-digital-dash-displays-adapter-harnesses/aemnet-can-bus-expansion-modules/6-channel-can-sensor-module
I made the CAN XML for you:
https://github.com/janimm/RealDash-extras/tree/master/RealDash-CAN/XML-files/AEM
You probably want to modify it to better suit your use, as this generic sensor device basically just outputs sensor resistance which in itself is not very useful.
