Hello everyone, I would like to know a little about how to integrate the Real Dash application to my vehicles, which I work with the AEM VCU300, which has two CANbus lines.
What would be the first step to follow? Is there a manual for this application?
I connect through the Kvaser Leaf Light 2 cable, is this compatible?
Once you establish the CAN connection between RealDash and your ECU, verify with CAN Monitor in connection settings that you are receiving frames. After that, we can go one step forward and see if any of our existing AEM CAN description files work with VCU300.
