I need an xml for Aem Infinity ecu
i am usint this app to EMU and Meagasquirt and it is very nice
i would like to use it and on my daily car that has Aem infinity ecu
I don’t know if AEM has published the CAN frame info. If this info is public, link it to me and I will take a look if I can make the XML for it.
AEMnet is public if this is what you mean: https://www.aemelectronics.com/files/pdf/AEMNet%20170116_Public.pdf
Have you check this?
can you make aemnet xml?
or can you help me with some info or a manual for making the xml to use it with aemnet canbus?
i want to conect with this via obd adapter. i have already obd port on the ecu with can high and can low conected directly from aem infinity for this reason.
Kindly regards
Stefanos Sarmatzis
S.S.ELECTRONICS
GREECE
I’m working on these:
Still needs to be tested, w/o starting the engine, so far IAT, Coolant seems to be working.
Everything is in US units, I’ll make SI versions later too.
