Hello-
Is it possible to add create an XLM file to support the AEM Vehicle Dynamics Module (part number 30-2206)? This is often used in conjunction with AEM Infinity. I’m thinking I could then just append this to the AEM Infinity XLM file. CAN configuration and message definition information is available online in the instructions, or I can forward.
Thanks for the consideration!
Sure, please link the CAN description, so I will use the correct one.
Are you available for testing the XML?
Hello, and thank you. Files are attached (pdf was too big, so they are screenshots).
Car is currently disassembled, but will be back together in the spring and I’ll be happy to try it out.
Best regards,
Jonathan
Ok, seems simple enough. So this is basically a external GPS device with CAN output.
Send me an email to contact@realdash.net with original PDF, and that I can send you the XML for testing.
