Android and CANable connection problems
Hi,
I started to write about problems with the canable can-to-usb adapter and android phone. Turns out that the specific adater had PCAN emulation firmware on it and thats why it didn’t work. Got firmware flashed to slcan finally and got it working at windows realdash. Some reason the slcan firmware does not work with linux/savvycan and therefore with the android phone. Have someone been dealing with the same problem?
-Sipi
Below is the orginal text that is about to post before I figured the firmware problem:
I have a aliexpress CANable copy can-to-usb adapter that I’m trying to use with android phone (samsung S24) . I have tried to send and receive can bus data in pc(savvycan at linux) with two CANables and it seems to be working correctly. I’m playing data recorded from the car with one adapter and receving it with the other. When I plug the adaptger to phone and try read the bus data with realdash I cannot receive it. Could it be thaht somehow the phone cannot acces to the adapter.
Description of current status:
- added the adapter as CAN/LIN device → SLCAN->SERIAL/USB->
- Phone finds the device: XCAN-USB
- tried all the baud rates 115200, 1228800, 2000000
- not touched the advanced settings
-can settings:
  • can frame:standard*
  • can speed: 500 kbps*
  • can mode: normal*
    - adapter red and blue leds are blinking constantly
Link to the adapter https://www.aliexpress.com/item/1005005963727624.html
BUT the can monitor shows nothing.
Any advices how to proceed?
For me it seems like you have done everything correctly. I have not personally tested that specific CAN adapter, so its possible that its serial chip is not in supported list in RealDash.
When RealDash is closed and you plug in the adapter USB, do you get an popup asking if you would like to use RealDash with that USB connection? If not, we need adapter VID and PID values in order to add it to the supported list.
I have same problem with Canable V1 with slcan firmware. With cangaroo software is working perfect.
If I remeber corret there was a pop up it. Here is the ID’s if it may help:
kuva
I fougth too many days with this and gave up and ordered usb can analyzer adapter from ali. That started working straight from the box, so :+1:
I guess that i should have order that adapter in the first place but I discovered realdash can features after having the adapter.
Thanks! This VID/PID is not in supported device list. Will add for next release.
helo,
I got the same problem, and I got the solution
first go to CANable firmware updater
then flash your adapter firmware to be SLCAN, using DFU mode
after that, you will be able to connect by: CAN/LIN->SLCAN->USB Serial
and it will make you happy
