This problem was detected. If you add a round indicator to the panel, then it has a 1: 1 aspect ratio. This is the norm …
But if I edit the panel again and save the panel again, then after entering REALDASH the round becomes oval. By itself. You see.
I think this is a serious problem.
If the words are not clear then look at the video width and height. Everything is visible there.
This is android 9
https://youtu.be/-4z7ROZfIWk
Allright, will take a look. What is the screen resolution of the device?
resolution - 2340 × 1080
aspect ratio — 19.5: 9
I think I found this problem and will push the fix to 1.6.4 release.
Thank! Will wait!
