As noted on previous thread, animated GIFs move at 10X speed created. Any plans to allow for control of speed of animation? maybe a setting to adjust speed…additionally, a cool feature might be to change speed with received value from input value.
Send me the gif and I will check why its speed is not correct on playback.
I just realized the speed issue has been corrected. However, this GIF does not render correctly. It leaves “wipe” trails behind as is draws. This should represent a pane of glass lowering.
Additionally, my second ask is still valid; Can a ECU value passed to Realdash control animation speed?
I will try to explain the problem
https://youtu.be/c1pyl1aLcjw
on the left is your animation, on the right, downloaded from the Internet.
what is the difference in them?
try to make a black background in your animation and you will be happy, at least then turn on blending in RealDash
try this animation
For playback control you may want to try to convert your gif animation to mp4 video file and use the video playback control actions.
I have not tried video playback mode; Is it possible to control playback speed with incoming value?
For example, If I want to show a radiator fan speed graphically, or electric water pump speed, or A/C wind speed? What are options for this?
several different animations - hide / show - optimally
