I have seen this code at the bottom of arduino examples. I am unsure of how to go about editing this portion of code. Notice commented out it says little Endian. How would one go about changing this to Big Endian?
Serial1.write(serialBlockTag, 4);
Serial1.write((const byte*)&canFrameId, 4);
// CAN frame payload
Serial1.write(frameData, 8);
Currently what i’m using:
void SendCANFramesToSerial(unsigned long canFrameId, const byte* frameData)
const unsigned long serialBlockTag = 0x11223344;
Serial.write((const byte*)&serialBlockTag, 4);
Serial.write(frameData, 8);
