Arduino Nano not communicatin with RealDash
Fellas,
Have issues connecting an Arduino Nano ESP32 wia USB/Serial with REal dash.
I loaded the arduino sample sketch from the repository with the sample RealDash application. I set up the connection as follows:
Adapter(CAN/LIN)–> RealDash CAN → Serial/USB–> Nano ESP32–>115200
RealDash_Example.XML
Data source in the settings tab is set to be “connections”
If I check the CAN monitor no data is shown, can’t establish …What I’m missing? What I’m doing wrong?
Probably the code is in the XML, in my case I need to change the labels, and gemini suggest me envolve all in a frame label
