Hello im using this code on my new arduino R4 wifi as an access point, i can connect with the phone to the wifi but when i go to settings in realdash it wants me to put enter ip adress in wifi/lan settings. What ip adress is it looking for, is it the phones ip adress or the arduinos?
I tried both ip adresses of the arduino wifi / and my samsung phone
#include <CAN.h>
#include "WiFiS3.h"
#include "arduino_secrets.h"
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;
WiFiServer server(35000);
WiFiClient connectedClient; // Declare the connected client variable
// RealDash CAN frame headers
const byte RD_FRAME_HEADER[] = {0x44, 0x33, 0x22, 0x11};
// Settings
#define CAN_SPEED (500E3) // Adjust this to your CAN network speed
#define SERIAL_BAUD_RATE 250000 // Adjust this to your serial communication speed
// Inits, globals
typedef struct {
long id;
byte rtr;
byte ide;
byte dlc;
byte dataArray[8]; // Adjust the size to match your CAN messages
} packet_t;
// Printing a packet to serial
void printHex(long num) {
if (num < 0x10) {
Serial.print("0");
Serial.print(num, HEX);
void printPacket(packet_t *packet) {
// packet format (hex string): [ID],[RTR],[IDE],[DATABYTES 0..8B]\n
// example: 014A,00,00,1A002B003C004D\n
printHex(packet->id);
Serial.print(",");
Serial.print(packet->rtr, HEX);
Serial.print(",");
Serial.print(packet->ide, HEX);
Serial.print(",");
Serial.print(packet->dlc, DEC);
Serial.print(",");
for (int i = 0; i < packet->dlc; i++) {
Serial.print(packet->dataArray[i], HEX);
Serial.print(",");
Serial.println();
// Forward a CAN packet as RealDash CAN '44' frame
void forwardAsRD44Frame(packet_t *packet, WiFiClient client) {
// RealDash '44' frame format:
// 4 bytes - 0x44,0x33,0x22,0x11
// 4 bytes - CAN frame id number (32bit little endian value)
// 8 bytes - CAN frame payload (data)
byte header[] = {0x44, 0x33, 0x22, 0x11};
client.write(header, 4);
client.write((byte *)&packet->id, 4);
client.write(packet->dataArray, 8);
// CAN RX, TX
void onCANReceive(int packetSize) {
// received a CAN packet
packet_t rxPacket;
rxPacket.id = CAN.packetId();
rxPacket.rtr = CAN.packetRtr() ? 1 : 0;
rxPacket.ide = CAN.packetExtended() ? 1 : 0;
rxPacket.dlc = CAN.packetDlc();
byte i = 0;
while (CAN.available()) {
rxPacket.dataArray[i++] = CAN.read();
if (i >= (sizeof(rxPacket.dataArray) / (sizeof(rxPacket.dataArray[0])))) {
break;
// Forward the received packet as RealDash '44' frame to the connected client
forwardAsRD44Frame(&rxPacket, connectedClient);
// Setup
void setup() {
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// Don't continue
while (true);
// By default, the local IP address will be 192.168.4.1
// You can override it with the following:
WiFi.config(IPAddress(192, 10, 0, 1));
int status = WiFi.beginAP(ssid, pass);
if (status != WL_AP_LISTENING) {
Serial.println("Creating access point failed");
// Don't continue
while (true);
// Wait 10 seconds for connection
delay(10000);
// Start the web server on port 80
server.begin();
Serial.begin(SERIAL_BAUD_RATE);
while (!Serial) {
// Wait for serial port to connect (needed for native USB port only)
if (!CAN.begin(CAN_SPEED)) {
Serial.println("Starting CAN failed!");
while (1);
// Register the receive callback
CAN.onReceive(onCANReceive);
Serial.println("CAN RX TX Started");
// Main
void loop() {
// Handle any other tasks if needed
// Check for incoming client connections
WiFiClient client = server.available();
if (client) {
Serial.println("New client connected");
// Set the connected client to the newly connected client
connectedClient = client;
