One of the issues (major issue) that i am facing on my VIM3L + Arduino x2 + RealDash setup is usb connection.
Not sure if others are facing such issue on other SBC brands but here is the issue that causes my whole dash to stop communicating to RD.
In my setup i am using two arduinos and they are running at different baudrates with two different xml files but everytime i restart the SBC or unplug the usbs it goes out of sync and RD wont be able to connect again and keeps resetting the connection for eternity.
main issue is arduino is not being recognized in either android or RD as arduino and its called “dev/bus/usb/00X”, on first connection X is 3 and is assigned to the first arduino that gets the connection so i usually end up having 003 and 005 on first connection so in garage i set them up, do a ignition off, sleep, reboot or unplug and plug usb back in and the name changes to 006 & 008 this happens sometimes until it reaches 065 & 067 (it may go more).
sometimes RD picks them up in the right sequence and everything is happy (although names were changed automatically from 003 to 065) but if RD takes them in wrong sequence 1 wont work and will keep on reseting itself.
Can there be a way to fix/hack it through RD app ? or atleast say the first connection is always arduino 1 and second connection is always arduino 2?
