Why can’t I set the aspect ratio to 8:3 in a Windows program? switches itself to 16:10
And another problem in the image
Thanks for reporting, will check.
Edit: Yes, the 18:9 setting was twice in the settings and is now fixed.
The 8:3 option works for me, at least on full-hd monitor.
Thank you, we will wait for updates
I understood what the joke is, you are checking the screen size, so the option 8 to 3 was not enabled. My taskbar was on the left, so the screen size didn’t match. I moved the taskbar down and the 8 to 3 option turned on
Ok, good catch. I will try to make it work regardless where the taskbar is.
