Average , fuel consumption showing incorrectly
hi
I bought the full version and if i see the trip details the information displayed seems incorrect.
attached screenshot…
I travelled around 2 Kms (kilometers) and the Fuel consumed and average fuel consumption shows very high i,e 4.3 liters consumed and 0.4km/l as average…
Is there any setting that i m missing? – currently in the APP setting for UNIT and Values i have set KM/H , distance units as Kilometers, fuel consumption display as KM/L
Also i have setup the car weight, Tank capacity,
i m using the dashboard " Swedish and Default dashboard…
kindly help… i m not able to attach the trip details image here…
regards
For the fuel consumption, please check that your engine size is set correctly on Garage. If your vehicle has MAF, its important to have correct engine size for the flow calculations.
Unfortunately, the formula is most likely incorrect.
I am transmitting the MAF, I have set the correct engine volume, but the average consumption is overstated by 29%.
By the way, the engine volume does not participate in the formula for calculating the average consumption.
instant consumption
Qfuel,L/h​= (MAF×3600)​ / (AFR×750)
average consumption = (InstC * 100) / Speed
That is pretty much what RealDash uses. Stoich AFR is used if AFR is not available from the vehicle.
