Good evening.
I own a 2004 Fiat Doblò with an OBD2 port.
Before purchasing, I’ll send you the data I collected with my diagnostics.
I’m attaching some photos showing the connected control units.
-Body computer
-Engine ECU
-Instrument cluster
-Airbag control unit
(In the engine ECU, you can view many parameters, including: engine speed, throttle position, fuel flow, boost pressure, and other things.)
(In the body computer, you can view:
Some information: doors closed or open, turn signals, and other things.)
(In the instrument cluster, you can view:
Odometer, headlight height, engine speed, fuel gauge, engine temperature, battery voltage, vehicle speed, and other parameters.
By purchasing the license, can I view all these parameters? Can I edit and create menus and submenus with the physical buttons on the steering wheel or touch screen?
I hope to receive some answers and contribute to the community. Thank you.
