Please help me figure it out.
I have ID401. Bit change occurs 00 to 01. How to describe the xml file for changing pages Stock - Sport?
That is, by default, bit 00 - the Stock panel works, when you click on the button, the bit change to 01 and the panel should change to Sports, when you press it again, it will be 00 again and the Stock panel should return. How to describe this xml file?
I made the event trigger the change Stoke-Sport when 00 goes to 01, it does not return to the back.
Typically the problem here is the ‘Reset Condition’ of your trigger. If its not set up properly your trigger may not be able to trigger more than once.
