blink speed parameter, must contain 2 values:
peak width (ms)
fall width (ms)
because at large values with these settings, for example, an interval of 2000 (ms) means that the symbol is displayed for 2 seconds and there is no symbol for 2 seconds - this is not very informative.
you need to be able to configure blink so that the symbol is displayed for 2 seconds and blinked briefly (0.5 seconds) for example!
I think adding this would just add complexity to Look’n Feel UI. You can implement more complicated blinking patterns with triggers and actions using the timers.
For OBD2 this is implemented as ‘skipCount’ on XML file. See documentation here:
For other connections it does not make any difference as all parameters are received constantly. With OBD2 you can gain some data rate as its a poll-receive type protocol.
