Hello everybody
why is there actually no way to generate a button to exit realdash…
Ralf
Hello everybody
Ralf
Minimizing realdash with a button would of course also be great
You can create a button with action that sets ‘App Started’ input to 0. That should close the app.
Hello! Jani! But when you select an action, set a value, the ‘App Started’ input cannot be accessed. Check it!
Instead, I do a little trick, I assign an action, “open any other application” which minimizes to the RD tray!
Ah, true. I forgot that this input is not available for Actions.
Hello,
yes, I noticed that too…
Another idea
Try that ^
Thanks a lot
Hello,
I got it easier
Simply create a new action with MINIMIZE APPLICATION and do not enter a PACKAGE NAME, then RD will be minimized
That’s exactly what I wanted to achieve…
Thanks at all
Cool!
Works great! Everything is correctly collapsed.
Question to Jani … Maybe then, if the application is running in the background, it would be possible to return the RealDash application via a USB connection by sending a specific command?
Of course I understand that this should only work in the background, but will not work when the application is closed
Try Launch app action with RealDash package id.
hmm, I didn’t think about it, I’ll try! Thanks!
It worked great! Thanks! I got what I wanted!
I got an idea, but I’ll open it in another post!
I got it easier
Hello,
if I minimize around, everything continues to run wonderfully in the background…
BUT
the navigation voice unfortunately not.
is it possible that the announcements in the background are still spoken?
BR
I will take a look of this.
You are great
