When I used calculated RPM input on Pole Position custom dashboard isn’t working good or don’t work it. The fuel consumption value is over than 1000 l/100km when I set up the fuel consumption correction factor to 0.01 (calculated).
Need more info, how is Calculated RPM wrong? Why do you need Calculated RPM, are you not connected to your vehicle at all?
Usage of calculated RPM is very uncommon. It is meant for setups that has no vehicle connection at all. RPM is calculated based on GPS speed and vehicle’s top gear and wheel size. So if your vehicle is properly configured in the Garage, calculated RPM will give you correct RPM when cruising with highest gear.
I don’t have OBD2 scanner. For gear source I use “Gear (Master Speed, RPM, Gear Ratio)” and isn’t calculated at all, change gear RPM is 3000 RPM, because majority of the streets are with speed limit. (Max RPM 8000) How set up the change gear calculated?
Current Gear cannot be calculated from GPS Speed only, sorry ![]()
