Yes, you would need to download a font file, fonts.google.com or dafont.com etc. has quite many.
Well, easiest way would be the following:
- Go to the Gallery and load default dashboard.
- Edit, select all gauges and delete all gauges.
- Now you can start adding your text and the fonts that were in use on default dashboard are available for you.
