Hello.
Found incomprehensible behavior when transmitting CAN data from an xml file.
Example:
<!-- ID101 transmission test 1 -->
<frame id="0x101" writeInterval="1000" size="8">
<value targetId="test_tx1" offset="0" length="4" initialValue=123456790></value>
<value targetId="test_tx2" offset="4" length="4" initialValue=223567890></value>
</frame>
<!-- ID102 transmission test 2 -->
<frame id="0x102" writeInterval="1200" size="8">
<value targetId="test_tx3" offset="0" length="4" initialValue=0x12345679></value>
<value targetId="test_tx4" offset="4" length="4" initialValue=0x22356789></value>
</frame>
<!-- ID103 transmission test 3 -->
<frame id="0x103" writeInterval="1400" size="8">
<value targetId="test_tx5" offset="0" length="2" initialValue=0x1234></value>
<value targetId="test_tx6" offset="2" length="2" initialValue=0x6789></value>
<value targetId="test_tx7" offset="4" length="2" initialValue=0x2235></value>
<value targetId="test_tx8" offset="6" length="2" initialValue=0x6185></value>
</frame>
<!-- ID104 transmission test 4 -->
<frame id="0x104" writeInterval="1600" size="8">
<value targetId="test_tx9" offset="0" length="1" initialValue=0x34></value>
<value targetId="test_tx10" offset="1" length="1" initialValue=0x12></value>
<value targetId="test_tx11" offset="2" length="1" initialValue=0x89></value>
<value targetId="test_tx12" offset="3" length="1" initialValue=0x67></value>
<value targetId="test_tx13" offset="4" length="1" initialValue=0x35></value>
<value targetId="test_tx14" offset="5" length="1" initialValue=0x22></value>
<value targetId="test_tx15" offset="6" length="1" initialValue=0x85></value>
<value targetId="test_tx16" offset="7" length="1" initialValue=0x61></value>
</frame>
The device for receiving data is your own. Correctly I only get ID104. All others have errors, but the incoming checksum is correct.
By ID101
Received 44 33 22 11 01 01 00 00 18 cd 5b 07 10 60 53 0d c3
where 1 value is 0x075bcd18, should be 0x075BCD16 (123456790)
… 2 value is 0x0d536010, should be 0x0D536012 (223567890) -
By ID102
Received 44 33 22 11 02 01 00 00 80 56 34 12 80 67 35 22 07
where 1 value is 0x12345680, should be 0x12345679
… 2 value is 0x22356780, should be 0x22356789 -
By ID103
Received 44 33 22 11 03 01 00 00 34 12 89 67 35 22 85 61 21 while the program RD is starting
… 44 33 22 11 03 01 00 00 00 00 00 00 35 22 00 00 05 when the program RD is running
where 1 value is 0x0000, should be 0x1234
… 2 value is 0x0000, should be 0x6789
… 3 value is 0x2235, should be 0x2235
… 4 value is 0x0000, should be 0x6185 -
By ID104 everything comes right.
Received 44 33 22 11 04 01 00 00 34 12 89 67 35 22 85 61 22
Can you check and fix the issue?
