Hi
I’m setting up some new buttons using the send CAN frame action.
How can I make a button so that it toggles between sending a can frame of 01 (on) and 00 (off). i.e. launch control on or off with one button.
I can only set one action to the button.
You would likely need to use a dummy value as what is being sent to the ecu for traction control, and use triggers to change the dummy value from 0 to 1 and back based off of the trigger being reset.
Thanks. I looked at a few of the premium dashes and understand it now.
It’s a lot of triggers and actions to create now.
You can add as many actions as you like for the button gauge. Using the dummy variable and associated trigger is the best approach though.
