Hi,
I have a Vipec plug &play ecu in my supra. Added obd2 can /lin connection in it. Which connection setup should I have with elm327 bt connector? Tried many combinations but nothing seems to be working.
Realdash says “connected” and checking pid setup but it ain’t officially connected however.
If you have configured your ECU to send OBD2 data, use the OBD2 connection type with ‘Generic SAE compatible vehicle’ profile.
If you are sending CAN data, use one of the supported CAN adapters:
And choose connection type as CAN/LIN Adapters->Your adapter type. Then select either Link ECU default CAN description or you your own custom one.
