Can’t select Gauge located in a Container in Hide Gauge action
In the Hide Gauge action, I cannot choose a specific Gauge that is located in a Container.
I can only select the Container.
Is this a bug or is it normal behaviour?
Kind of a both. Containers were first added simply to animate multiple gauges at the same time, so in that sense yes its intented.
But now that containers are ‘public’ and used for many other things, one would expect to be able to animate individual gauges. I will check if I can fix this without breaking something else.
That would be awesome, as I learned the hard way that doesn’t currently work.
I had a set of gauges on a pop out menu I wanted to show. Then select different thinking that group.
So it would be nice to do each gauge sperate in a group/container as they all will hide together, but only want one to show at a time.
Hope you figure it out
I did, fix will be in next release.
