Hi ive had a look and it kind of looks possible but i cant make sense of the UI or how to edit anything.
I have the data engineers dream dash and want to display oil temp but cant see how to add it in?
Im using realdash on a windows tablet linked to an ME442 ecu.
Any help would be most welcome
Easiest way would be modifying an existing gauge to show oil temp.
- Enter into Edit mode and select the gauge you want to change
- Tap ‘Input & values’ on top menu and Select Data Source to ‘Engine Oil Temperature’
- Check your gauge range min and max, and also the warning and critical levels.
- Select the title text in the gauge and go to ‘Look’n Feel->Font & Text’
- Change the text, for example Oil Temp
- Below that is the units text, you can change that in a same way as title text.
- Save your dashboard.
- Change the input to ’
Cheers, i will give it a try.
