I have the canbus message coming into Realdash and I’m trying to sink it with a text gauge for an oil pressure readout. I know I’m doing something simple wrong but still have not figured it out. Thank you in advance
Here’s what I have:
My can message reads from 00 00 00 00 00 00 00 00
to FF 00 00 00 00 00 00 00
and all bits in between in that first row…
Hi,
I can’t troubleshoot your canbus messages incoming, but so long as you have defined the realdash can xml in the garage as a connection then you can create any gauge with “test pressure analog” as the data source.
For some reason I believe I have the XML incorrect as I can watch the canbus message change but I get no reaction on the gauge. I’m using a bar gauge to be able to see a rise and fall but I get nothing.
Finally got it, XML issue for sure. Actually a me issue.
