So here’s something that I’m running into. I have RD sending targetID 86 and 87 on ID 10 as shown in this XML
<frame id="10" writeInterval="10">
<value targetId="86" offset="0" length="1" endianess="big" ></value> <!--App started-->
<value targetId="87" offset="1" length="1" endianess="big" ></value> <!--App Shutdown-->
</frame>
And here is what I’m seeing on the can messages
10:35:29.953 -> 10 1 0 0 0 0 0 0 0
10:35:30.047 -> 10 1 0 0 0 0 0 0 0
10:35:30.142 -> 10 1 0 0 0 0 0 0 0
10:35:30.237 -> 10 1 0 0 0 0 0 0 0
10:35:30.332 -> 10 1 0 0 0 0 0 0 0
10:35:30.572 -> 10 1 0 0 0 0 0 0 0
10:35:30.620 -> 10 1 0 0 0 0 0 0 0
10:35:30.716 -> 10 1 0 0 0 0 0 0 0
10:35:30.764 -> 10 1 0 0 0 0 0 0 0
10:35:30.811 -> 10 1 1 1 1 11111111 11111111 11111111 11111111
10:35:30.811 -> RDClosedMsg = 1
10:35:30.811 -> 10 1 0 0 0 0 0 0 0
10:35:30.905 -> 10 1 0 0 0 0 0 0 0
10:35:30.952 -> 10 1 0 0 0 0 0 0 0
10:35:31.094 -> 10 1 0 0 0 0 0 0 0
10:35:31.237 -> 10 1 0 0 0 0 11111111 11111111 11111111
10:35:31.237 -> 10 1 0 0 0 0 0 0 0
10:35:31.379 -> 10 1 0 1 1 11111111 11111111 11111111 11111111
10:35:31.379 -> 10 1 0 0 0 0 0 0 0
10:35:31.520 -> 10 1 0 0 0 0 0 0 0
10:35:31.566 -> 10 1 0 0 0 11111111 11111111 11111111 11111111
10:35:31.614 -> 10 1 0 0 0 0 0 0 0
10:35:31.660 -> 10 1 0 0 0 0 0 0 0
10:35:31.708 -> 10 1 0 0 0 0 0 0 0
10:35:31.756 -> 10 1 0 0 0 0 0 0 0
10:35:31.803 -> 10 1 0 0 0 0 0 0 0
10:35:31.851 -> 10 1 0 0 0 0 0 0 0
10:35:31.899 -> 10 1 0 0 0 0 0 0 0
10:35:31.993 -> 10 1 0 0 0 0 0 0 0
The format above is is the first number, (10) is the canID and then the 8 bytes after.
The target is for the first byte to be that RD is open, and the second byte is for RD appshutdown. When I’m getting a 1 for byte 2, RD is open and just sitting there. Plus there is the 11111111 that you can see on the above bytes that are not pointed to anything and should be 0. Any ideas?
