Greetings.
I will give an example of a device based on the nano arduino that can read the CAN 2.0 bus using the Lawicel protocol.
This device works through the MCP2515
Here is the code you need to fill in arduino:
#include <can.h>
#include <mcp2515.h>
#include <CanHacker.h>
#include <CanHackerLineReader.h>
#include <lib.h>
#include <SPI.h>
#include <SoftwareSerial.h>
const int SPI_CS_PIN = 9;
const int INT_PIN = 2;
const int SS_RX_PIN = 3;
const int SS_TX_PIN = 4;
CanHackerLineReader *lineReader = NULL;
CanHacker *canHacker = NULL;
SoftwareSerial softwareSerial(SS_RX_PIN, SS_TX_PIN);
void setup() {
Serial.begin(115200);
while (!Serial);
SPI.begin();
softwareSerial.begin(115200);
Stream *interfaceStream = &Serial;
Stream *debugStream = &softwareSerial;
canHacker = new CanHacker(interfaceStream, debugStream, SPI_CS_PIN);
//canHacker->enableLoopback(); // uncomment this for loopback
lineReader = new CanHackerLineReader(canHacker);
pinMode(INT_PIN, INPUT);
void loop() {
CanHacker::ERROR error;
if (digitalRead(INT_PIN) == LOW) {
error = canHacker->processInterrupt();
handleError(error);
error = lineReader->process();
handleError(error);
void handleError(const CanHacker::ERROR error) {
switch (error) {
case CanHacker::ERROR_OK:
case CanHacker::ERROR_UNKNOWN_COMMAND:
case CanHacker::ERROR_NOT_CONNECTED:
case CanHacker::ERROR_MCP2515_ERRIF:
case CanHacker::ERROR_INVALID_COMMAND:
return;
default:
break;
softwareSerial.print("Failure (code ");
softwareSerial.print((int)error);
softwareSerial.println(")");
digitalWrite(SPI_CS_PIN, HIGH);
pinMode(LED_BUILTIN, OUTPUT);
while (1) {
int c = (int)error;
for (int i=0; i<c; i++) {
digitalWrite(LED_BUILTIN, HIGH);
delay(500);
digitalWrite(LED_BUILTIN, LOW);
delay(500);
delay(2000);
[/color]
