Hi Guys, brand new to Realdash and Im loving it so far, Im having a problem where realdash doesnt see my paired items in Bluetooth, this includes OBDII.
I have followed the instructions, My garage/connections/add/OBDII/Bluetooth, when I get here the screen is blank, there are no selections.
I have confirmed my tablet is connected to bluetooth and paired with OBDII and its showing OBDII in the connections. I confirm it connects to Torque and to CarWebGuru, and it all works properly connecting to realdash on other devices.
I have followed the advice and uninstalled/reinstalled realdash, but get the same thing over and over.
Ive tried to link via wifi but constantly get the display trying to connect to wifi. With no result.
Anyone experienced this, and have any suggestions what to try?
Any help gratefully accepted, it will be a real pity if I can use realdash to its full potential.
Obviously there is something wrong, but it would be next to impossible for me to attempt fix without the exactly the same device to duplicate the problem. Maybe you can try:
Unpair your Bluetooth device
Disable device Bluetooth
Make a full cold restart for your Android device, disconnect battery if mounted permanently
Boot and enable Bluetooth
Pair your Bluetooth device
Then try again. On some 4.x Android I have had to do that sequence after Bluetooth has gone unresponsive.
