Changing can speed
Hi, I’m having a problem with my MeatPi. I bought it a while ago, and with the MeatPi Dual CAN, you can change the speed in 250k, 500k, 800k, and 1000k increments using a jumper. I need 100k, though. Does anyone know how to change this? The shop says you can ask if you need different speeds, but unfortunately, I’m not getting any response from Ali Slim at MeatPi. Maybe someone knows a solution to this problem; otherwise, it was probably a bad purchase.
