Im currently working on a community dash.
Porshe
Author falcon_s2
How can i change all the values. I have my settings set for SAE. Yet it still shows metric. How can i change this. Or is there any reference pics i can use or…![]()
Porshe
Author falcon_s2
If the dashboard is using our standard inputs, you can change all units from ‘Settings->Units & Values’
Yes my settings are set as such. It seems to be on the community dashboards where everything is in metric. Also theres a language barrier on trying to edit. So if they aren’t realdash settings how can they be changed
If dashboards do not use RealDash internal inputs, only way to change the units is to edit the dashboard.
Ok. Well is there a fourm that can show me how to do so. I dont wanna bother u all day
Don’t worry, I won’t do that for you for all day ![]()
Just experiment, after couple of hours its not that hard anymore. Keep backups of your dash files in case you (or RD) mess up something.
Roger that. Ill play with it all weekend. If i have any concerns ill contact you monday
