Composite ID need help
i send can frame, after i try get in RealDash
please help found my mistake
if i try use Composite ID i all time not get my data
Looks correct. Is your composite ID of 43 05 50 01 sent from device as little or big endian? If your device is sending the composite ID as little endian, you could try:
<frame id="0x58A:0x43055001,0,4">
yes, I tried both options, I tried in composite ID 1 byte… and I don’t get any data at the reception if use composite ID. now I have solved the problem through triggers.
please, who used it, please write, rechecked everything, it doesn’t seem to work, however, I cannot confirm 100% that there is an error in the program.
