Hi!
I think that the COMPOSITE_ID feature is not working as documented, or I might be making a mistake somewhere.
Here’s a sample frame from RealDash’s CAN Monitoring:
000007e8: f4 49 db 00 00 00 00 00
And here’s the XML definition:
<frame id="0x7E8:0xF449,0,2">
<value name="Value ABC" offset="2" length="1" conversion="V/2.55"></value>
</frame>
Expected value would be around 85.9%, but I get zero on gauges.
I’ve seen another post from 2021 with a similar example, but no solution: https://www.realdash.net/forum/viewtopic.php?t=1348&start=10
