COMPOSITE_ID stopped working in one position
hello, for some reason, the mapping with COMPOSITE_ID 0X8e in this xml snippet stopped working.
 <frame id="0x140810ff:0x8e,1,1" endianess="big">
      <value targetId="38" offset="2" length="2" signed= "true" conversion="V/10"></value>      <!-- Spark Advance -->
    </frame>
I had to change it to:
 <frame id="0x140810ff:0x01,0,1" endianess="big">
CAN Monitor:
What is your actual composite ID byte, 01 or 8e?
Currently 01,It was the 8E and in some update it stopped working.
i have same problem Composite ID need help - #4 by Falcon_S
Edit: I found the issue, this same issue also affects @Falcon_S.
When using composite ID, the value having any of the:
signed="true"
float="true"
double="true"
will bleed into the composite id parsing resulting invalid composite id.
This is fixed for next release.
I still can’t use the composite ID. I have inverted the byte order. It didn’t help.
An example of a frame from CAN:
Blockquote
000007e8 : 05 62 24 D7 xx xx aa aa
056224D7 is a composite iD.
xx xx - this is data in two bytes.
<frame id="0x7e8 : 0xD724, 2, 2">
 <value targetId="31" offset="2" length="2"></value>
But the value is always “100” for some reason
please help me to match the values in XML correctly?
Seems like your composite ID is 4 bytes and data bytes start from offset 4:
<frame id="0x7e8:0xD7246205,0,4">
    <value targetId="31" offset="4" length="2"></value>
Or composite ID may be 0x056224D7 depending on endianness of the sending device.
